Equipement
default Equipement
Message  Maïté le Mar 02 Sep 2008, 01:57
Et le numéro direct d'AVON France : 08.25.16.01.00
Maïté
Maïté
Nombre de messages : 741
default PLAQUETTE AP RACING
Message  Toff le Jeu 25 Sep 2008, 16:28
Toff
Toff
Nombre de messages : 2033
default Re: Equipement
Message  Toff le Mer 30 Sep 2009, 11:16
FORMULA 1 AND FORMULA 2 RACING SIDECARS
At Maxton all of our shock absorbers are built to order, because of this we can manufacture shock absorbers specifically designed for Sidecar racing. As well as the shock being the correct length and eye sizes, we have also strived to perfect and design the best valving or damping rate for each manufacturer of sidecar. The combination of both these factors means we supply preset shock absorbers to suit the make of sidecar, the rider weights and what you use the sidecar for. We supply shock absorbers to all the major manufacturers of
Racing Sidecars :
Louis Christen from LCR
Terry Windle
Dave Molyneaux
Tony Baker
Joe Shelbourne
Mike Richards from M.R Equipe
As well as supply shock absorbers directly to the manufacturers, we also supply shock absorbers for different makes of sidecars to replace the shock absorbers already fitted such as Louis Christian, Joe Heys, Derbyshire and a number of one off chassis.
FRONT SHOCK ABSORBERS
For the front of a Formula 2 sidecar (and the front of a Baker Formula 1 outfit) we supply a pair of Maxton Twinshocks. They are Alloy bodied dampers, externally adjustable for rebound damping, they have spherical bearings at either end to reduce the load on the seals and have threaded preload adjusters for infinite adjustment. They cost £385.00 + V.A.T.
For the front of a Formula 1 LCR outfit we supply a Maxtonunit and remote reservoir that costs £520.00 + V.A.T.
REAR SHOCK ABSORBERS
We supply three different models of rear shock absorber for Formula 1 and Formula 2 outfits :
Maxton Gas Shock £405.00 + V.A.T This is adjustable for rebound damping, compression damping and preload as well, because it contains gas it has a bigger range of damping adjustment and does not lose it's damping or "go off" in long races. The gas shock is recommended if you have a Formula 2 outfit and intend to compete at the T.T.
Maxton Gas Shock with remote reservoir £520.00 + V.A.T. This is adjustable for rebound damping, high and low speed compression damping and preload. Because it contains gas it has a bigger range of damping adjustment and does not lose it's damping or "go off" in long races. The gas shock is recommended if you have a Formula 2 outfit and intend to compete at the T.T. This is the shock used on Dave Molyneaux and Tony Baker and
Toff
Toff
